Ketan Decorators
Aluminium System Windows
Vadodara’s Trusted Aluminium System Windows Manufacturer & Supplier
We totally get it. Choosing the right windows is not just about picking something that looks nice. You want natural light flooding in. The cityscraper views from your office should be clear. That is exactly what our aluminium system windows deliver.
Whether you are building from scratch or renovating an old place, our windows are designed to fit your needs perfectly. As one of the trusted aluminium system windows manufacturers and suppliers in Vadodara, Gujarat, we don’t believe in cookie-cutter solutions. We offer honest guidance and quality materials we’re genuinely proud of.
From first chat to final fitting, we will be right there with you. We make sure everything goes smoothly and you end up with windows that make you feel brilliant every single day.
Our Aluminium System Window Solutions
Slim Windows
Sometimes you want the glass, not the frame. That is where slim aluminium windows really shine. We are talking about frames so narrow (around 6-15mm in some cases) that they practically disappear. It gives you massive panes of glass and views that go on forever. They are perfect if you are after that clean look without sacrificing strength or insulation.
Minimal Windows
Now, if you really want to push the boat out, minimal windows are where things get exciting. Massive panels, barely-there frames. If you have seen them in fancy hotels or high-end homes and thought "I want that," we can absolutely make it happen. And they are tougher than they look. Minimal windows have lock shutters of 6mm and the interlock sections are as thin as 16mm.
Why Choose Aluminium System Windows for Your Project?
SINCE 1998
Why Work With Us?
Our team does not just follow instructions from a manual. They have worked on tricky heritage buildings, awkward openings, and every challenge you can imagine. So when something unusual crops up, they know how to sort it properly.
That experience counts for a lot when you are trusting someone with a big investment in your property.
Everything we make is built specifically for your project in our own factory. We are not ordering standard sizes from somewhere else and hoping they fit. We measure your openings precisely and build windows that slot in perfectly.
 Heritage proportions? Unusual sizes? No problem. You get exactly what you want, not the closest thing we happen to have in stock.
We are a bit obsessive about the small stuff, to be honest. Corners have to line up perfectly. Everything has to open and close smoothly. Finishes need to be spot-on. Our installers check each window before fitting it.
And we inspect everything before we call a job finished. We take pride in what we do. You will notice the difference when you see the finished result.
We don’t disappear for weeks without updates. We tell you what is happening, when it is happening, and if there is a problem. You get constant updates from us straight away. You get a proper contact person who knows your job inside out.
Building work can be stressful enough. So we make a point of keeping you in the loop.
Job done does not mean goodbye forever. We give you all the care instructions, warranty paperwork, and our number in case you need anything down the line. If something is not quite right, we come back and sort it properly.
We want you happy not just on installation day, but 5 years later too. That is how you build a proper reputation. We stand behind our work.
Quality does not have to mean getting fleeced. Because we make everything ourselves and fit it ourselves. There is no chain of people taking a cut. That saving goes straight to you. Our quotes are clear.
What you see is what you pay, no nasty surprises later. We price fairly because we would rather have happy customers coming back than squeeze every penny out of one job.
Recent Aluminium System Windows Projects
FAQ
How long do aluminium windows typically last?
They last for ages. Good aluminium windows systems will easily give you 45 to 60 years. Sometimes even longer. Bit of cleaning and the odd drop of oil on hinges is all they need. We have seen windows from the 90s still going strong. Compare that to other materials that start looking tired after 15 years.
Yeah, really efficient actually. Modern ones have these thermal breaks built in. If you are adding double glaze, they will work even better. People are often surprised by this because old aluminium windows from decades ago were freezing. But the technology has moved on massively.
Pretty much any colour you fancy. We powder coat them at the factory in whatever RAL or BS colour you choose. You can even have different colours inside and out if you want the exterior to match your brickwork but the inside to suit your décor.
They cost more upfront than plastic, similar to decent timber. But you never have to paint them, they do not need replacing after 20 years, and they save a lot of energy. Add it all up over the life of your space and aluminium often works out cheaper overall.
Basically anything you want. Casement windows, sliding-folding, fixed panes, pivot windows and a lot others. Within each style you can choose different handles, glazing patterns and opening directions. We also do floor-to-ceiling glass with them. Aluminium is versatile enough that it is rarely the limiting factor.
Yes we do. We have worked with conservation officers loads of times. Sometimes getting planning approval takes a bit of back-and-forth, but we know the process and what they are looking for.
Want to know what we could do for your place?
Drop us a line and we will arrange a visit or call about what is possible and what it might cost. Let us create something long-lasting that you will love for years!
Scroll to Top
